98 swap pcm - FirebirdV6.com/CamaroV6.com Message Board
98 swap pcm
  • 98 swap pcm
    I am doing an engine swap my car is a 98 but i am putting a 97 motor in. Can I use the wiring harness that is on the 97 motor or do I need to change the 98 wiring harness to the 97 motor?
    Re: 98 swap pcm
    They should be interchangeable, especially that the 97 + 98 both still have the throttle-by-cable. Just make sure you have the same type of transmission (ie: auto or manual).
