My camaro has about 70,000 miles on it, and I get only 17 mpg. I do both city and highway driving, and do not drive like an *** lol. Is it possible that I may need a new o2 sensor?
o2 sensor
Re: o2 sensor
if you need a new o2 sensor these people are really cheap:
http://automedicsupply.com/2002 Silver Metallic A4 Firebird - All Options
Hotchkis STB, Custom Madrel Bent 3" Exhaust, Pacesetter Headers, Whisper Lid, FT Ram Air, K&N Air Filter, D2S HID, Baer Rotors, !EGR, !MAF, 10% tint, Parrot CK3300
Your Mom or My Dad?
Re: o2 sensor
When I was getting low gas mileage I did a home tune-up and it helped out tremendously. Replace spark plugs, spark plug wires, fuel filter, oxygen sensors. Clean or replace air filter. Run some engine cleaner through it. Change oil and filter. Change differential fluid. While you're at it flush and fill the radiator. I've you have the original wires in there or non-performance ones I have found them to be a little flaky and not standing up well to the test of time. When I did this years ago I think 3 of the wires snapped off of the boot when I tried to pull them. Doing this got me back to the upper 20's for mpg.
Re: o2 sensor
Originally posted by kristenit could be alot of things. we will need a list of your mods. and it might be in your best interest to get a dyno done to see if your running rich or lean.
Originally posted by FireShadowWhen I was getting low gas mileage I did a home tune-up and it helped out tremendously. Replace spark plugs, spark plug wires, fuel filter, oxygen sensors. Clean or replace air filter. Run some engine cleaner through it. Change oil and filter. Change differential fluid. While you're at it flush and fill the radiator. I've you have the original wires in there or non-performance ones I have found them to be a little flaky and not standing up well to the test of time. When I did this years ago I think 3 of the wires snapped off of the boot when I tried to pull them. Doing this got me back to the upper 20's for mpg.
i always keep up on these thing meticulously, im average about 25 city easy. thats not even trying to get the most out of it either.<a href=\"http://cardomain.com/id/articacid\" target=\"_blank\">2002 35th Anniv. Black Camaro M5</a><br />Mods: Carsound Cat, SLP Loudmouth, Whisper Lid w/ K&N, J&M LCA\'s, ST Springs, eD Stereo(146.7 dB)<br />\'88 K1500 305 V8 Auto(Winter)
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...12 hours ago
