fog light help - FirebirdV6.com/CamaroV6.com Message Board
fog light help
  • fog light help
    How do you replace a foglight on a 97 Camaro? Do you have to remove the plastic cover, and replace the seal with silicone, or what? I know the screw in front just adjusts the hight of the light, but I cannot see how you would get the light out to replace it. Thanks for any help, and yes i have run a search, but i didnt really come up with anything for a 97 camaro. Thanks again
    97 Camaro<br /><br />K&N Hi-Flow CAI, Xlerator into Dual<br /> <a href=\"http://www.cardomain.com/id/camaaro\" target=\"_blank\">http://www.cardomain.com/id/camaaro</a>
    Go from the bottom of ,right underneath the area where the fog lights are.There is a little square access panel,just swing it out & voilla the bulbs will be there!
    geocor
      thanks man [img]smile.gif[/img]
        I dont know if you were thinking of a different year, but there is no little square access panel that i could find... i could barely fit my hand into the area where the bulb was, so unless this is harder than im making it, someone please fill me in on how to change a fog light bulb on a 97 camaro... thanks [img]smile.gif[/img]
          Thought it was the same as my '98?If there is no screws on the lenz ,its probably like a 98+, where you have to remove a panel or something & get it from behind?!
          geocor
            yes... im assuming thats what you have to do, because there are some panels at the bottom, and i treid to squeeze my hand around them, barely touched the blub harness though lol... so ill have to mess around with the panels im assuming... thanks
              This should answer all your questions...
              http://www.bfranker.badz28.com/fbody/fogs.htm
              1994 Arctic white, 3.4l, 5spd<br /><br /><a href=\"http://www.cardomain.com/id/montytrmpt\" target=\"_blank\">http://www.cardomain.com/id/montytrmpt</a>
                Thanks, that guide solved my problem [img]smile.gif[/img]
                • 187shark
                  by 187shark
