well my belt is whining, and i have come to the conclusion it is the belt because baby powder on the belt solves the problem for a little while, what brand belt do you reccommend?
belt whine
Re: belt whine
i beleive that most belts are the same but alot of the car shows like to use a goodyear gatorback belt, you could also try using a can of belt condisioner. but it would probably be just as easy to replace the belt.K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
Re: belt whine
Just replace it. all belts are practically the same, since you aren't doing any heavy racing. I'd say go with the gatorback myselfCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
Re: belt whine
I've heard of MORE problems with noise than not with the Gatorback when I searched here.
Gates are good. I'm running a cheaper Korean-made one [you know how the parts stores have the choice of the expensive or the cheap belt]. Since the belt is so easy to change on our cars, I figured the cheap one was worth a shot.\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
Re: belt whine
i like my gatorback, it doesnt make any noise at all2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: belt whine
Originally posted by terminaldegreeI've heard of MORE problems with noise than not with the Gatorback when I searched here.
Re: belt whine
I put on a $35 Dayco belt from advanced auto. No problems or belt whine. Got Dayco belts on my 69 as well.69 Camaro 350 4spd, Full Hotchkis susp, Baer brakes, moser 12 bolt, Flowmaster<br /><br />96 RS Hotchkis STB, subframe connectors, Hotchkis LCA and adj Panhard rod, SS camaro sway bars, Bilstein shocks, powerslot rotors, Borla exhaust, rksport headers, k@nFIPK
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...10 hours ago
