Good spark plug - FirebirdV6.com/CamaroV6.com Message Board
Good spark plug
  • Good spark plug
    With my mods im going to list, should i be looking for standard? Platinum?
    Right now i run a AC delco #1 rapid fire.
    Now i do plan on running the bottle later on in the summer, then ill switch to a NGK tr6, but for now for these mods all motor what would be good?
    2030 Crane cam
    Forged .30 over Ross pistons
    20% more flow melling oil pump
    block bored .30 over
    P&P heads 3 angle valve job
    P&P upper and lower intake
    All Comp valvetrain parts Hardened Pushrods
    1.6 Rockers
    5.0 #19 injectors
    and some other things.
    New:04 GMC Sierra 1500 RCLB 4x4 5.3 GU80 3.73\'s.<br />Truck pics<br />Mods<br />Go fast: Panel K&N filter and soon SS truck catback.<br />Appearance: Stull Billet grill,Weston Chrome step tubes,Rhino Chrome hitch step,ARE painted fiberglass cover,Silver star lighting.
    Run copper plugs. The platinums have given a lot of people a lot of problems, REGARDLESS of their engine setup. They just don't perform well. The copper plugs do fine and are not something you will have to worry about or question.
    1996 Camaro w/ Y87 package. T-Tops, purple, loaded. Custom painted salad-shooters with Mirage paint.<br /><br />(It\'s my girlfriends car!)
      TR55 without spray, TR6 for when you do spray:)
        I all ways get copper ones.
        That cam plus the extra .03''bore you could go 1 heat range colder if you run into any unexplained detonation.
          autolite coppers are my first choice.
          second choice for me are the ngk tr55's.
          (this is for NA)
          96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view&current=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
            So tr55's good on 3.4 all motor?
            thanks for the advice keep it coming ;)
              I am running the iridium plugs with my nitrous setup. I have basically the same internals that you do plus a little more here and there. I wanted to stay away from the copper plugs and with nitrous, iridium is basically the only other option.
                Re: Good spark plug
                platnums suck on my car for some reason.
                  Re: Good spark plug
                  what he said
                    Re: Good spark plug
                    I use NGK V-Power plugs UR5, which are copper. Very good plugs, no issues.
                      6 days ago
