some of my lights on my dash never come on like the low trac if i spin the tires purposely it still wont show is there something wrong with my sensors.. and also i disconnected the maf sensor and plugged it back in and now my ses light wont go away should i disconnect the battery???
low trac???
Re: low trac???
low trac light tends to come on when you've activated the ABS. The light should come on for a few seconds with the key turned on as a bulb check.\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
