ALL GM Technical Bulletins for 1998 camaro\firebird!!!! - FirebirdV6.com/CamaroV6.com Message Board
  • ALL GM Technical Bulletins for 1998 camaro\firebird!!!!
    #73-82-12 ERRATOC OP. OR HEADLAMP DOORS, HEADLAMPS, OR TURN - (10/08/1997)
    #87-61-23 ACCESSORY BELT NOISE/SQUEAL (DIAG. /REPL. APPLICABLE PART) - (04/20/1998)
    #23-50-05B REDUCING DISC BRAKE COME BACKS (NEW TOOL KIT & POLICY CHANGE) - (11/10/1997)
    #33-17-01A PAINT PEELING FROM MUFFLER (NEW REPAIR PAINT AVAILABLE) - (12/01/1997)
    #73-81-34 ANTI THEFT ALARM MAY SOUND AFTER VEHICLE - (08/14/1997)
    #83-15-12 CONVERTIBLE TOP MECHANISM BINDS OR STOPS WHEN HALFWAY - (07/17/1998)
    #87-65-18 ON-BOARD DIAGNOSTIC SYSTEM IMPROVEMENTS - (05/18/1998)
    #43-17-01B BUMPS OR RUST COLORED SPOTS IN PAINT DUE TO RAIL/IRON DUST - (07/31/1998)
    #99-06-04-007 Illuminated MIL Light (Diagnose/Reflash Calibrations) - (02/22/1999)
    #99-06-01-007 Technical - Accessory Drive Squeak (Replace Idler Pulley) - (05/07/1999)
    #99-01-38-001 Tech - A/C Comp Failure During Aggressive Eng Accel (Reprogram PCM) - (05/28/1999)
    #99-07-30-013 Tech - Service Engine Soon (SES) Light Illuminates (Repl Switch Assy) - (07/27/1999)
    #99-06-04-037 Tech - On Board Diagnostic (OBD) System Improvements (Reprogram PCM) - (09/02/1999)
    #99-08-67-002A Tech - Tick Noise from Roof Panel Near Sides (Reinf Roof Panel Joint) - (10/07/1999)
    #99-08-45-005 Accessory Receptacle is Inoperative (Check Aftermarket Device Plug) - (11/08/1999)
    #99-05-23-002A Rear Brake Groan/Chirp Noise During Brake Apply (Replace Rear Brake Pads) - (11/29/1999)
    #99-05-23-006 Front Brake Squeal At Light/Moderate Brake Apply (Install Frt Disc Brake Pads) - (12/06/1999)
    #00-06-01-008 Accessory Drive Belt Squeak/Chirp Noise (Install Idler Pulley/Gen. Bracket/Belt) - (03/22/2000)
    #00-06-01-011 No Oil Indicated On Dipstick (Replace Dipstick Tube and Dipstick) - (05/01/2000)
    #00-08-110-004 Rear Quarter Trim Gaps to the B-Pillar (Insert Screw) - (10/11/2000)
    #00-07-30-022 No Reverse, Second Gear, or Fourth Gear (Replace the Reaction Sun Shell) - (11/10/2000)
    #00-08-57-004 Water Runs Out of Front Lower Corners of Rear Hatch When Opened (Install Sealer) - (11/29/2000)
    #01-08-42-002 Headlamp Door Squeaks When Opening or Closing (Apply Lubricant) - (02/28/2001)
    #01-07-30-021 Park/Neutral Position Switch Connector Cannot Be Removed (Replace Switch and Connectors) - (05/02/2001)
    #99-01-39-004A Air Conditioning Odor (Install Kit) - (05/22/2001)
    #01-08-64-003A Window Motor Noise (Replace Motor) - (07/24/2001)
    #01-03-10-009 Plastic Wheel Nut Covers Missing and/or Loose (Replace Missing Covers and Add Sealant to all Covers) - (11/01/2001)
    #01-08-57-009 Rear Floor or Trunk Wet on Top of Axle (Apply Sealer) - (12/17/2001)
    #02-07-31-001 Clutch Pedal Return Spring Breaks or Scraping Noise When Clutch Pedal Applied (Replace Clutch Pedal Return Spring) - (02/19/2002)
    #02-08-44-003 Buzz or Rattle Sound from Speaker Locations (Add Foam Tape to Speaker Grilles or Door Panels) - (02/27/2002)
    #01-07-30-023B Harsh 1-2 Upshift, SES, MIL, or CEL Illuminated, DTC P1870 Set (Replace Valve Body) - (03/22/2002)
    #02-08-66-006 Gas Cap Tether RIvet Breaking (Install New Rivet) - (04/30/2002)
    #02-06-04-023A Audible Spark Knock (Detonation), MIL Illuminated, DTC P0332 Set (Replace Rear Bank Knock Sensor and RTV Area Around Sensor) - (06/14/2002)
    #02-06-01-029 Needle Bearings Found In Oil Pan (Replace Rocker Arms) - (08/28/2002)
    #02-06-03-006A No Start, No Crank, Battery, Batteries, Generator, Gages, SES, SIR, Brake, Security, Theft, ABS, Hot, DIC Messages, Lamp, Light, Battery and Generator Diagnostic Testing, and Cadillac Roadside Service - (11/26/2002)
    I am a pontiac tech, and these are taken from GM's tech info website. These are all of the GM bulletins for the 98 camaro and firebird. I have access to almost all years. If you want any of these bulletins, let me know and i will sent you the whole bulletin!!!!
    yeah, I better cover my butt cause I don't think I'm supposed to be giving out this info..
    GENERAL MOTORS BULLETINS ARE INTENDED FOR USE BY PROFESSIONAL TECHNICIANS, NOT A "DO-IT-YOURSELFER". THEY ARE WRITTEN TO INFORM THOSE TECHNICIANS OF CONDITIONS THAT MAY OCCUR ON SOME VEHICLES, OR TO PROVIDE INFORMATION THAT COULD ASSIST IN THE PROPER SERVICE OF A VEHICLE. PROPERLY TRAINED TECHNICIANS HAVE THE EQUIPMENT, TOOLS, SAFETY INSTRUCTIONS AND KNOW-HOW TO DO A JOB PROPERLY AND SAFELY. IF A CONDITION IS DESCRIBED, DO NOT ASSUME THAT THE BULLETIN APPLIES TO YOUR VEHICLE, OR THAT YOUR VEHICLE WILL HAVE THAT CONDITION. SEE A GENERAL MOTORS DEALER SERVICING YOUR BRAND OF GENERAL MOTORS VEHICLE FOR INFORMATION ON WHETHER YOUR VEHICLE MAY BENEFIT FROM THE INFORMATION.
    COPYRIGHT 1998. GENERAL MOTORS CORPORATION. ALL RIGHTS RESERVED.
    GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information. WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
    © Copyright General Motors Corporation. All Rights Reserved.
      Your right. You're not supposed to give out this information. Cheers to you for during it though. I know I wouldn't, I like my job to much.
        We appreciate those [img]smile.gif[/img] [img]graemlins/thumbsup.gif[/img]
        2002 5-spd NBM Camaro
        Details: www.1lev6.com
          You missed a few. [img]smile.gif[/img]
          http://www.alldata.com/TSB/48/984802IB.html
          This site is in the Technical Database.
          Raven
            Do TSB still apply to vehicles out of warranty??
            1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
              This is great information, any chance we can get this moved to the archive?
              Not a problem, just a challenge...
                yes, they do apply, but don't mistake these for recalls. These are just to assist gm techs in fixing you car. It is kind of like gm saying we have seen this quite a bit, so check this first. Use these for your own knowlage and to help yourself with problems. Just because there are these bulletins, it does not mean your vehicle have these problems. Basically it is one big gm tech help thing.
                  what about us 96's???
                  2005 Chevrolet Corvette C6 <br />M6, Magnaflow\'s 14336<br /><a href=\"http://community.webshots.com/user/v6purplebird\" target=\"_blank\">C6 Pics</a><br /><br />Old car:<br />1996 Firebird A4<br />SLP Cold Air Intake<br />Magnaflow Catback Exhaust<br />Magnaflow Catalytic Converter<br /><br />George Mason University<br />CEIE Major<br />Pi Kappa Alpha<br /><br /><a href=\"http://members.cardomain.com/nsolano\" target=\"_blank\">Firebird Pics </a>
                    <blockquote>quote:</font><hr>Originally posted by Gmtech1005:
                    yes, they do apply, but don't mistake these for recalls. These are just to assist gm techs in fixing you car. It is kind of like gm saying we have seen this quite a bit, so check this first. Use these for your own knowlage and to help yourself with problems. Just because there are these bulletins, it does not mean your vehicle have these problems. Basically it is one big gm tech help thing.<hr></blockquote>
                    Oh, thanks. I reread what I wrote and I stated it wrong. I thought they were free fixes, but I got it confused with recalls....nevermind me....hehe
                    [img]graemlins/burnout.gif[/img]
