will the LS1 injectors fit our cars. I wanna get either 38# or 42#'s for my turbo set up and the only ones i can find on ebay are for ls1's which are a pretty decent price...
V8 injectors??
Re: V8 injectors??
well LT1 injectors I know are #24. I would assume that LS1 injectors are about the same. might be less that what your looking for. if you go too small you will have to spend even more money. if you go too large you can tune it down with HP tuners if you have a 3.8L.95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------> <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
Re: V8 injectors??
Originally posted by andrew.brandonwell LT1 injectors I know are #24. I would assume that LS1 injectors are about the same. might be less that what your looking for.
L67 injectors are 36 pound, that might be enough for you.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
Re: V8 injectors??
150 shipped for my 57#'ers ohm tested them and there's nothing wrong, only removed to upgrade to 65# lolwww.turbov6camaro.com
1997 3800 Series II Camaro
Re: V8 injectors??
Originally posted by Kidcamaro98ok well what size injectors should i get if i wanna run 12 PSI on a T70?www.turbov6camaro.com
