keyless entry - FirebirdV6.com/CamaroV6.com Message Board
keyless entry
  • keyless entry
    k broke the keyless entry and need a new one. thing is dont know where to find one.help. also how do i tune it so it works with my locks? plzz help im very lazy i cant continue to use the key!!!!
    2001 camaro a4 SOM vert <br />3800 series II <br />flowmasters american thunder <br />3.42 gears<br /><br />its not fast but i drive it like a natural beast
    Re: keyless entry
    I had one go out on me and I bought one for cheap off of ebay.
    I forgot how the programming went, it was something like turn your key on and off like 3 times but don't start it up, then the locks and lights turned on and off, which signaled programming mode or something. I will get back to you on the instructions, unless someone else jumps in here in the meantime and answers it.
    http://www.bowtiev6.com/
      Re: keyless entry
      It says how to reprogram it in the owners manual....
      You have to take out the radio fuse, and put the key in the ignition and turn it 3 times in 5 seconds. And than hold unlock and lock for like 10 seconds, and you locks should work.....
      1998 White Camaro 3800, A4, MagnaFlow Cat-Back, Zexel & 3.42's, Jet Chip Stage 2, Whisper Lid, and Ram Air.
        Re: keyless entry
        this is for the stock remote?
        because i just recently had my bcm replaced, and since i got it replaced my remote hasnt worked and i was wondering how to fix it
        <a href=\"http://www.cardomain.com/memberpage/808840\" target=\"_blank\">My 1996 V6 T-Top Camaro</a>
          Re: keyless entry
          1- Pull the radio fuse out
          2- Put the key in the ignition, sit inside of the car with the doors closed and turn the ignition on/off three times without starting the car.
          3- The third time turning the key, leave it in the ON position in the ignition (without starting), and you will hear the interior beep confirming.
          4- Then hold the Unlock and Lock buttons on the remote for approximately 10-15 seconds. You'll hear the locks engage confirming the new program.
          5- Replace the Radio fuse, and your done.
          The radio fuse needs to come out so that there is no power to keep memory in the ignition (you know how our car's have the 10 minute delay once the key is turned off?). There is NO memory loss in the radio station programming, it just disengages the 10 minute ignition delay.
            Re: keyless entry
            There it is ^^^^ thats how you do it.
              Re: keyless entry
              where is the radio fuse.
              thnx soo much for the help i really needed it lol. everytime i have to open the door with the key my friends try to open they're door and it ALWAYS sets off the alarm lol. thnx alot
                Re: keyless entry
                in the fuse panel on the drivers side of the dash
                  Re: keyless entry
                  My keyfob works, but seems to be very weak.. sometimes I have to press the button, and wave it around the car, and it has to be up close.
                  Is the battery just low, and can I replace it?
                    Re: keyless entry
                    replace the battery unless you messed the buttons up and they aren't making contact anymore
                      Re: keyless entry
                      If the buttons are messed up they are very easy to take apart and put back together. Sometimes if it gets dropped, it can loosen the connection to the battery, so it just needs a little bending to get it back into place.
                        Re: keyless entry
                        thanks! it worked perfectly, i was tired of not being able to lazy, heh
                          Re: keyless entry
                          no i mean like which fuse??
                            Re: keyless entry
                            look in your manual or on the fuse box cover for fuse diagram. That will show ya which one is the radio fuse
                              Re: keyless entry
                              bottom right hand side when looking at it, i think its yellow if i remember right, i'm pretty sure it is the bottom right
