k broke the keyless entry and need a new one. thing is dont know where to find one.help. also how do i tune it so it works with my locks? plzz help im very lazy i cant continue to use the key!!!!
keyless entry
Re: keyless entry
I had one go out on me and I bought one for cheap off of ebay.
I forgot how the programming went, it was something like turn your key on and off like 3 times but don't start it up, then the locks and lights turned on and off, which signaled programming mode or something. I will get back to you on the instructions, unless someone else jumps in here in the meantime and answers it.
Re: keyless entry
It says how to reprogram it in the owners manual....
You have to take out the radio fuse, and put the key in the ignition and turn it 3 times in 5 seconds. And than hold unlock and lock for like 10 seconds, and you locks should work.....
1998 White Camaro 3800, A4, MagnaFlow Cat-Back, Zexel & 3.42's, Jet Chip Stage 2, Whisper Lid, and Ram Air.
Re: keyless entry
this is for the stock remote?
because i just recently had my bcm replaced, and since i got it replaced my remote hasnt worked and i was wondering how to fix it<a href=\"http://www.cardomain.com/memberpage/808840\" target=\"_blank\">My 1996 V6 T-Top Camaro</a>
Re: keyless entry
1- Pull the radio fuse out
2- Put the key in the ignition, sit inside of the car with the doors closed and turn the ignition on/off three times without starting the car.
3- The third time turning the key, leave it in the ON position in the ignition (without starting), and you will hear the interior beep confirming.
4- Then hold the Unlock and Lock buttons on the remote for approximately 10-15 seconds. You'll hear the locks engage confirming the new program.
5- Replace the Radio fuse, and your done.
The radio fuse needs to come out so that there is no power to keep memory in the ignition (you know how our car's have the 10 minute delay once the key is turned off?). There is NO memory loss in the radio station programming, it just disengages the 10 minute ignition delay.
Re: keyless entry
where is the radio fuse.
thnx soo much for the help i really needed it lol. everytime i have to open the door with the key my friends try to open they're door and it ALWAYS sets off the alarm lol. thnx alot2001 camaro a4 SOM vert <br />3800 series II <br />flowmasters american thunder <br />3.42 gears<br /><br />its not fast but i drive it like a natural beast
Re: keyless entry
replace the battery unless you messed the buttons up and they aren't making contact anymore
Re: keyless entry
If the buttons are messed up they are very easy to take apart and put back together. Sometimes if it gets dropped, it can loosen the connection to the battery, so it just needs a little bending to get it back into place.
Re: keyless entry
look in your manual or on the fuse box cover for fuse diagram. That will show ya which one is the radio fuse
