Ok i installed the switch about a week ago...but i only have low speed that works...the high speed worked the first time i tried it then stopped...a couple days ago it was on again...any clue on whats goin on?
manual fan switch ?
Re: manual fan switch ?
Originally posted by SilverRS96Ok i installed the switch about a week ago...but i only have low speed that works...the high speed worked the first time i tried it then stopped...a couple days ago it was on again...any clue on whats goin on?
the fans didnt come on when i flipped the switch tho...they just came on no matter what...i flipped it to low and it was still on high so i dont know whats up with that but ill check the connections tomorrow
87 Firebird RIP
96 Camaro RS RIP
94 Patriot Red 1LE Z28 - Sold
02 WS6 TA - Sold
is this with the car off or on that you are trying to turn them on?
Your fans will still operate as they normally would, the switch is just an override so that you can turn them on when the fans would otherwise be off or on high when they would otherwise be on low.Old Car = 12.679 @ 106.5 on 150 dry shot.
New Car = 2010 3.6l 304hp Camaro
manual fan switches usually are used and work good when your car is off. Let your fans work normally when the car is on.
I programmed your fans to come on sooner because of the thermostat when I programmed your 97 PCM so you shouldn't need to be turning your fans on while the car is on.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...22 hours ago
