i posted this earlier, thinking it was an EVAP problem, but thats not whats causing my troubles. my car runs normal when i push the pedal lightly (rev's up to 3000 rpm's fine) but when i merge or accelerate more heavily, there is a VERY noticable loss of power, and near the top of my rev range, im getting a clicking noise and stop accelerating from that point. well now a set of spark plugs, wires, coil packs, and fuel filter later, the problem still exists. ANY help or ideas are greatly appreciated, cause i have no idea what could be wrong. thanks in advance!
loss of power in higher rev's
Re: loss of power in higher rev's
My suggestion would be to go down to a gm dealer and have them diagnose the problem before you throw any more money at it.
They should be able to pinpoint the problem within an hour and it could save you money in the long run. I was having similar, yet more severe symptoms that what you are describing and I cahnged the whole electrical side of the ignition with no success.
I eventually ran out of idas and took it to a dealership and an hour later found out I needed a new catalytic converter.Representin' Team Red In The North
Red '96 Pontiac Firebird "Smokeshow" 3800, M5, Far From Stock!!
Black/Red '89 Jeep Cherokee "Tigerclaw" Chev 327, Turbo 400... Stock What??
Black/Red '02 Honda CBR 954RR Fireblade
sounds like a cat converter is clogged
This is a driveability issue... and since you have a '00, take it to a dealer or shop to be scanned. The OBD-II has over 200 sensors to help control the car. It could be anywhere. Most would think it's the cat... and I would agree if this was an OBD-I car... but it's not. Sensors (map,TPS,CPS,etc) all play a VERY big part in what the motor does as you push the throttle.
SteveFirebirdV6.com/CamaroV6.com Administrator
Stupid is rewarded with the ban button.
Official Avatar Nazi according to Meatyshells :D
Coudl be the cat... thats my first guess... Are you throwing any codes? I say take it to autozone get it scanned. If you have a '00 it will tell you that the CAT is clogged.
If its not that and the ignition is all good I would be leaning towards a fuel issue. Pump/injectors-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
Originally posted by 00 Silver 6how does a cat get clogged that fast though? i left for KY and everything was fine, and a day after i got back the power just dropped off. wouldnt a clog be a slow, building problem?
I pulled the exhaust off and cut out the cat and it was seriously messed up inside.
Like I said before, take it to the dealership to be diagnosed before you throw any more money at it, and whatever you do, dont get the car fixed there.Representin' Team Red In The North
Look under the car at the cat after you've driven for a bit. Is it red hot? If so, it's definitely the cat.1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...1 day ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...3 days ago
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...2 weeks ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...3 weeks ago
