ses light - FirebirdV6.com/CamaroV6.com Message Board
ses light
  • ses light
    ok well since i have headers, y pipe, high flow cat and then the o2 sensor, my ses light stays on. cause it's too hot or something. anyways, my car has to get inspected by sat. and i was talking to a guy and he said even if you disconnect your battery to reset your computer it will still get pulled up while they are running your car. is that true? i'm looking into getting the casper sim. but then i don't think that i will pass since the it's a sim. i could go to autozone and rent their scanner and clear my codes and hopefully it stays off till the car is finished. someone give me some answers please
    WAWA-A-HOLIC
    Re: ses light
    For peace of mind, I would have autozone clear the code. I remember reading that dis/reconnecting the battery won't clear the PCM's memory, so the light wouldn't be on, but it would still read as a DTC. How far is the Zone from the inspection place? most the time it'd take about 50 miles for a DTC to pop back up after it's cleared.
    hope that helps.
    2011 Camaro LS 6M, in black.
      Re: ses light
      Kristen, give me a ring. I have a OBD II scanner that scans and clears codes.
        Re: ses light
        when you clear the codes, you cannot pull them back up, they are gone. if you fix the problem and the light goes out itself, the codes stay in there.
        if you clear it, you WILL NOT PASS. if you clear the codes it actually clears everything and restarts the entire system test. it takes a little while for it to complete the tests too. newer cars are not sniff tested, as long as the computer says all of your emissions equipment is working and you pass the visual you will be ok.
        so basicly you have to fix them problem.
        you dont know exactly which code it is? is it the 420, cat below efficiency? if it is a caspers sime will fix the problem.
          Re: ses light
          i know in jersey that if it's 96 or newer the run odb2 tests on it .Meaning that even if you clear the codes just before you go it will fail because the drive cycle has not completed . Wich could take as long as fifty miles . I don't know how pa is though.
            Re: ses light
            i love indiana, no emmissions!
              Re: ses light
              An Actron scanner is a great investment that will come in handy any time you get a code. Costs about $150. You'll have it forever. Go to Autozone or Advance Auto Parts for one.
              Scan the code, fix the problem, clear the code, then get it inspected.
              Yes, that code will be stored in the computer even after the problem is fixed, so if you want it out of there, you'll have to use a different software program or have the dealership clear it out. Stored codes are NOT an issue when it comes to inspection. Only the SES light with a present code. I use both the Actron Scanner (handheld, easy to use) and Autotap (for more detailed readings and clearing codes) on a laptop.
              2004 CE Corvette 10.86@132mph
              2011 Cadillac CTS-V
              2006 Mitsubishi Eclipse GS
                Re: ses light
                I have a sim that I'm looking to sell since I have Hp tuners now. It worked perfectly when I had it on and I just took it off like 2 weeks ago. I'll give you a good price if you're interested. Let me know
                Old Car = 12.679 @ 106.5 on 150 dry shot.
                New Car = 2010 3.6l 304hp Camaro
                  Re: ses light
                  kristen don't you have HPT? edit the ***** out...
                    Re: ses light
                    yea I thought you had hp tuners? You can get rid of it that way easily
                    http://www.bowtiev6.com/
                      Re: ses light
                      well what i did was , went to hockeymans to use his obdII scanner. and then i drove to the shop (10 miles) and it still wasn't ready. went and drove another 20 miles came back and still not ready. did another 15 miles and still nothing. so i took it home. and i have her out today. and probably doing another 20 miles by the time i get there. i know the guy with the shop so i can scan it all i want. i'll keep you posted
                      WAWA-A-HOLIC
                      • 187shark
                        by 187shark
