ok well since i have headers, y pipe, high flow cat and then the o2 sensor, my ses light stays on. cause it's too hot or something. anyways, my car has to get inspected by sat. and i was talking to a guy and he said even if you disconnect your battery to reset your computer it will still get pulled up while they are running your car. is that true? i'm looking into getting the casper sim. but then i don't think that i will pass since the it's a sim. i could go to autozone and rent their scanner and clear my codes and hopefully it stays off till the car is finished. someone give me some answers please
ses light
Re: ses light
For peace of mind, I would have autozone clear the code. I remember reading that dis/reconnecting the battery won't clear the PCM's memory, so the light wouldn't be on, but it would still read as a DTC. How far is the Zone from the inspection place? most the time it'd take about 50 miles for a DTC to pop back up after it's cleared.
hope that helps.2011 Camaro LS 6M, in black.
Re: ses light
when you clear the codes, you cannot pull them back up, they are gone. if you fix the problem and the light goes out itself, the codes stay in there.
if you clear it, you WILL NOT PASS. if you clear the codes it actually clears everything and restarts the entire system test. it takes a little while for it to complete the tests too. newer cars are not sniff tested, as long as the computer says all of your emissions equipment is working and you pass the visual you will be ok.
so basicly you have to fix them problem.
you dont know exactly which code it is? is it the 420, cat below efficiency? if it is a caspers sime will fix the problem.<a href=\"http://cardomain.com/id/articacid\" target=\"_blank\">2002 35th Anniv. Black Camaro M5</a><br />Mods: Carsound Cat, SLP Loudmouth, Whisper Lid w/ K&N, J&M LCA\'s, ST Springs, eD Stereo(146.7 dB)<br />\'88 K1500 305 V8 Auto(Winter)
Re: ses light
An Actron scanner is a great investment that will come in handy any time you get a code. Costs about $150. You'll have it forever. Go to Autozone or Advance Auto Parts for one.
Scan the code, fix the problem, clear the code, then get it inspected.
Yes, that code will be stored in the computer even after the problem is fixed, so if you want it out of there, you'll have to use a different software program or have the dealership clear it out. Stored codes are NOT an issue when it comes to inspection. Only the SES light with a present code. I use both the Actron Scanner (handheld, easy to use) and Autotap (for more detailed readings and clearing codes) on a laptop.Last edited by Shirl; 04-25-2006, 09:55 PM.2004 CE Corvette 10.86@132mph
2011 Cadillac CTS-V
2006 Mitsubishi Eclipse GS
Re: ses light
I have a sim that I'm looking to sell since I have Hp tuners now. It worked perfectly when I had it on and I just took it off like 2 weeks ago. I'll give you a good price if you're interested. Let me knowOld Car = 12.679 @ 106.5 on 150 dry shot.
New Car = 2010 3.6l 304hp Camaro
Re: ses light
kristen don't you have HPT? edit the ***** out...-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
Re: ses light
yea I thought you had hp tuners? You can get rid of it that way easily
Re: ses light
well what i did was , went to hockeymans to use his obdII scanner. and then i drove to the shop (10 miles) and it still wasn't ready. went and drove another 20 miles came back and still not ready. did another 15 miles and still nothing. so i took it home. and i have her out today. and probably doing another 20 miles by the time i get there. i know the guy with the shop so i can scan it all i want. i'll keep you posted
