size - FirebirdV6.com/CamaroV6.com Message Board
size
  • size
    Does anybody know the inlet/outlet size of the stock radiator and heater hose(s). I'm replacing my water pump with an electric one and I need to know the size of the hoses as well. Thanks.
    -Chris
    1994 Camaro<br />3.4L V6 Automatic<br />K&N FIPK&Gold Oil Filter,Ravin Performance Exhaustw/Dynomax MandrelBent3\"I-Pipe&S Pipe&Catco 3\" HiFlow Cat.,ASP Crank and High AMP Alternator,U.D. Pulley Set, Bosch Spark Plugs and Oxygen Sensors, Taylor Wires, B&M E.ShiftPlus, 160 thermostat,Zexel Torsen L.S.D., CSI Remote Mount Electric Water Pump & Temp. Controller & Flex Hoses, ALM. Drivshaft, Diamond SubFram Conn.<br />COMING SOON: 350 or 502 RAMJET ENGINE & Big Block Hood<br />NJ V6 F-Body Club<br /><a href=\"http://tristategm.com/NJFbV6/\" target=\"_blank\">http://tristategm.com/NJFbV6/</a><br />Street Lethal F-Body Association <br /><a href=\"http://www.slfba.com./index.html\" target=\"_blank\">http://www.slfba.com./index.html</a>
    come on somebody has to know
    [ March 11, 2002: Message edited by: Skullcamaro ]</p>
      Why dont you take some string and measure the circimference, find the radius using that measurement and C=2piR, then round to the nearest hose size?
      2002 5-spd NBM Camaro
      Details: www.1lev6.com
        Sorry i cant help w/ the hose size Cardinals idea sounds good to me... ill just tell you before you get hounded on shorten you sig dude and dont post it if you already have it in a thread. not trying to be a D!ck just a heads up [img]graemlins/burnout.gif[/img]
        AIS 2 OHH the memories... Great times and putting names with faces.<p>From \"interesting\" hooters waitress(Did you guys FLY ? ) to pissing BMW owners off on the ride home. To ending up in Philidelphia and USING (hahaha) an ice machine. I had a BLAST.<p>Thanxs to all that showed up!!
          Yeah cardinals Idea Is A gOoD iDeA. I used it to measure stock exhaust.
          1995 Camaro 3.4 v6. Dead<br />1995 Trans Am FIPK.
