oil in my throttle body - FirebirdV6.com/CamaroV6.com Message Board
  • oil in my throttle body
    Well, it's been happening for a while now. I always noticed oil in my throttlebody. Everyone on here told me it was my pcv valve not sucking up the oil or whatever. I changed it and it still did it. Can this be a sign of something?
    When I changed mine out I noticed the same thing. I'm thinkin' its OLD collections of blow-by or just a small leak somewhere. If I were you, I would take ur tb off then clean it out the best you can. When you reinstall it, check on it after a week or so and see if anything new appears.
    <b> \'95 Camaro 3.4L A4 <i>Rikku</i><br />AutoX - Drift - Street </b><br />\"Sideways is faster.\"
      U sure its the oil?
      Maybe its all the crap from the EGR.
      1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
        Are you sure that it's not fuel? Oil would be a deathly sign. Mine is the case that I have a valve that periodically stays stuck open. And, fuel pours into it. Something I NEED to get fixed... :(
        Soon to be Mommy!<br />2005 Honda Pilot EX-L
        • Andy H
          Transmission removal help!!
          by Andy H
        • 2.8 Bird
          Abs inop
          by 2.8 Bird
        • fishin
          by fishin
