how much extra - FirebirdV6.com/CamaroV6.com Message Board
how much extra
  • how much extra
    ok heres the deal i have a 2000 camaro v6 3800 series II, its a 5 speed manual and from what i already know i have a stock 200hp. but i have some mods to it and i was wondering what my overall gain from all of my mods put together is, ok so heres what ive done:
    flowmaster exaust (2.5 in), cold air intake, k&n high flow filter, whisper lid, free mods like cutting the extra plastic off of the intake and raising it, also cut the foam out of my front bumper where the air slots are in the plastic nose cover to create a ram air effect.
    i have already tried the search function and cannot find all of the parts plus the free mods that i have done, but if ne one could give me an estimate on how much extra that would give me i would greatly appreciate it !!!
    thanx again
    Re: how much extra
    every car is different, only way to figure it out is get to the dyno. My guess would be 178rwhp.
    http://www.bowtiev6.com/
      Re: how much extra
      ok ur guess is 178rwhp but how much is that going up from stock??
        Re: how much extra
        8-10 rwhp gained from your exhaust and intake. Numbers could be higher but every car is different and those are some common numbers for gains. Some people see better than that.
          Re: how much extra
          also one more question what do u think that i should add next, ive heard a different gear, or headers or what would u suggest?
            Re: how much extra
            i know i said 1 more but i lied lol do they make a performance intake manifold for the v6 camaro???
              Re: how much extra
              you already have the tubular manifolds so headers won't gain you much at all. I would go with gears/lsd next if you still have the 3.08 gears
                Re: how much extra
                no, they dont
                2000 3.8 A4 Pewter Camaro
                  Re: how much extra
                  do they make one, no, can you get the stock one ported, yes.
                    Re: how much extra
                    178 I thought the camaro came with 200 horses where did you get 178 from he said it was stock and he added stuff so shouldn't his horsepower go up
                      Re: how much extra
                      200 is flywheel power, not horsepower to the rear wheels
                        Re: how much extra
                        he stated 178rwhp (Rear Wheel Horse Power)
                        our cars came with 200 fly wheel horse power
                          Re: how much extra
                          Ive talked to a couple people that have done dynos on stock 3.8 fbodys, and the usual is around 170 rwhp. Lots of factors come into play though. You can make as much power as you want, but the dyno isn't going to read it if you cant put it to the ground. A LSD will help you there. You have an advantage with the 5-speed though, less power is lost through a manual compared to an automatic. If im not mistaken, its like a 25% power loss through the transmission.
                          Black 1996 3.8 Firebird T5, SLP CAI, Pacesetter Ceramic Headers,160* t-stat, PCMforLess Tune, Flowmaster American Thunder catback, Car Sounds Cat, custom s-pipe, MSD coils and wires, NGK plugs, 3.42 posi rear, B&M Ripper, 245/50 BFG-G-force's
                            Re: how much extra
                            Its about 15%-20% for an automatic on rwhp loss.
                            Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
                              Re: how much extra
                              200 is in your engine. but you lose 15% of that hp getting to your back wheels. i'm saying that you have nothing more that 175
                              i know it sucks
                              cause im my engine i have 357.65 hp. i want that to go to the ground. heheh
                              WAWA-A-HOLIC
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
