Well he is haveing oil pressure problems his oil pressure will fluctuate from 25 at idel to 45 at WOT he has changed oil twice and replace the oil pressure sending unit. any help at all would be great thanks alot.
I have a friend with a 95 3.4L camaro who needs help
<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport HeadersTags: None
All of our rides have "ify" oil pressure readings. Though that is a drastic change between idle and WOT. Has he had someone look at it, mechanic wise???
New ride: 98 firebird-y87-appearance package-t=tops-MINT-Tri-flo installed sounds unbelievable [img]graemlins/burnout.gif[/img]
Old ride: 94 camaro- t-tops-tri-flo-K&N-underbody neons-Unbelievable condition- SOLD
That's not uncommon. Mine does the same and the pressure is actually fine.94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
yeah he had it checked and the pressure was fine<b><a href=\"http://www.sick-sixx.com\" target=\"_blank\">SICK-SIXX MEMBER</a></b><br />NA 14.345 with a 1.863 60 foot<br />Nitrous 13.03@99.5 with a 1.63 60 foot<br /><br />2000 Camaro 3.8L A4: USE TO HAVE Comp Cam 210/220 .535/.547 113lsa 111 I/C, Port and Polished Heads, NX Wet Kit 100 Shot, CPRA made by CP, RK Sport Headers
i have had the same probleme for a while now scared me bad at first at frist crank the pressure is ok the longer i drive the more it fluctuates greatly and if i sit at idle sometimes it will pull a oil pressure light where is this switch you speak of ?1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
the oil pressure switch is located right above the oil filter it is screwed right in to the engine block ./
what happens when these things go out is that oil is getting all the way threw the switch so if there is oil on the side of your engine do not be alarmed
I assume he has the right size filter.
I had low oil pressure ended up being the dealership put the wrong size filter on my car. Lucas Oil Stabilizer works pretty well.
here is a small review I wrote about it at www.fbodyv6.com
http://www.fbodyv6.com/modules.php?o...wcontent&id=12
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...2 days ago
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...5 days ago
by 187sharkHi all new to the community here. I have a 2014 RS 6 speed manual... and so about a year ago my tail lights got cracked and eventually the plastic housing...2 weeks ago
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...3 weeks ago
