Hi. I have a crack in my back window about 5 inches long and i was wondering if they can tint over it or not?
Tinting over crack?
Re: Tinting over crack?
Have you repaired the crack? If not I'd recommend using a glass cutter and cutting a small line forming a 'T' just a bit further than your crack at either end. 95% of the time the crack will run into the cut you've made and it will stop. Once you have stopped the crack then you can tint over it and shouldn't be a problem.
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...5 days ago
