Electric Water Pump - FirebirdV6.com/CamaroV6.com Message Board
Electric Water Pump
  • Electric Water Pump
    Is a Electric Water Pump a good Idea for v6 f bodies and what does the Plug-and-play wiring harness plug in to and does the drive belt on a 97 fit a 96.
    Re: Electric Water Pump
    decent mod for high rpm power, not going to see anything in low rpms. It would be one of the last bolt ons I would do though. I would get exhaust, intakes, gears/lsd and such taking care of first.
    plug and play harness you are talking about I believe is a relay system that turns the pump on when the car is started instead of you having to flip a switch every time to turn it on.
    Drive belt will be the same from 96 to 97.
    http://www.bowtiev6.com/
      Unless you are getting it REALLY cheap - there are better mods for the dollar.
      95 Camaro Black<br />3.4 V6<br />Automatic<br />Stock 3:23 rearend<br />Custom CAI<br />Flowmaster muffler w/dual outlets<br />Chrome 5 spoke wheels from 2000 Camaro with 245-50R16 Goodyears<br />Chrome decals on front and back.<br />Car Bra<br />Its a start.......<br /><a href=\"http://www.elderon.xohost.com/carpics.html\" target=\"_blank\">www.elderon.xohost.com/carpics.html</a>
