Dazed and Confused.... - FirebirdV6.com/CamaroV6.com Message Board
  • Dazed and Confused....
    Ok, not entirely dazed and confused but I have a question. I recently added BMR SFC to my car (Auto,3.42,LSD) and I got on it for the first time since having them installed, I did this going through a turn and I felt and heard a single loud pop noise (similar to popping your knuckles) could that be from the SFC or rear end? I just want to make sure it is nothing to worry about or if it is normal to hear those noises, btw radio was off so i could hear my car. I know I haven't provided much info but I dont know what else to add. Ask and I'll tell. Thanks!
    Re: Dazed and Confused....
    are these weld in or bolt in? i dont have sfc's but anytime you hear loud popping noises right after a modification its a cause for concern. if it were me, i'd check every place where it connects to the car.
    Visit My F-Body Page
      Bolt on with spot welds in various locations
        Maybe the spot welds werent good enough and popping off?
        1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
          Ok, it def. has nothing to do with the sfc's however, while just cruising without throttle down a slight hill i hit a bump and the single loud pop came from right behind my drivers seat near the rear axle im guessing. I'm guessing rear shock? make sense since the car might torque that way during a turn and cause the shock to compress or the panhard bar mount cracked??
