Last year i had my a/c compressor replaced along with the other a/c components and recharged. Well today it got hot and i turned it on and let it run on high for like 5 min. and it didnt work. I didnt hear it kick on like it did when it worked. Any ideas. I havent ran it all winter if that matters.
a/c problem
There could be an electrical problem. Compressor not receiving voltage to activate the clutch. Bad pressure switch on the compressor.
Or maybe the refrigerant leaked out. If the compressor senses there is no refrigerant it wont turn on as a safety measure so the compressor wont seize up.
Also make sure the controls are set to A/C and cold. Sounds dumb, but it's happened to me a few times after a long winter.1994 Chevrolet Camaro 3.4L A4 (160hp 200tq)<br />2006 Nissan 350Z 3.5L M6 (300hp 260tq)
Another very common problem is the electrical connector on top of the clutch (in 3rd Gen cars it's there anyways, I don't know where on a 4th) tends to get messed up from people washing the motor or resting on it while working on the car, etc...
I've seen 2 A/C problems solved in the past month by wiring another connector in.
where is the low side port for recharge ?Ummad!<br />2k pewter maro M5. 160 thermo, WhisperLid w/K&N Filter, Jet PCM Stage 2, Free Ram Air, Air Silencer Delete (purchased already and) waiting to install manual fan switch, air/fuel ratio guage.
Well i refilled it and its blows out ice cold air, i rechecked it after about 20 minutes and it still read correct preesure range, to recharge it, look on the silver cannister that is behind the battery, it has a little black cap on it. Unscrew that and while the car is running with the a/c on max hook up the bottle to it and refill to the right pressure reading.96 Polo Green Camaro<br /><br />Slp Cai,Flowmaster American Thunder cat-back,Catco cat,3.42 Posi rear, KMC Floss Rims 275/45/17 rear 235/45 front
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...3 hours ago
