Is there any signs that you can tell when the MAF is failing.
MAF sensor failing
Re: MAF sensor failing
Originally posted by 380099CamaroIs there any signs that you can tell when the MAF is failing.
Have it checked first because it can start becoming REAL expensive if you don't get it right. There are too many other sensors or relays that could cause the same symptoms. Have it scanned. A bad MAF will throw codes like p0100,p0101,p0102,p0103.sigpic
Originally posted by 380099CamaroI had it scanned and code P0102 came up..Does that mean I need to replace it? Also code 1514 and 1516 came up..Would those codes come show because of the code 0102
As for the other two codes, I have no idea...sigpic
Originally posted by 380099CamaroIf the MAF died or what ever happens to them if they stop working..would it keep the car from starting?
Fix the problem now or spend alot more later...sigpic
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
