what all should i get done beside plugs and wires and fuel filter, what plugs and wires are best i was thinking the accel 8.8 mm wires and bosch platinum +4 plugs..what else should i get done i bought a whisper lid and am going to clean my throttle body without removing it is that a good idea?
major tuneup???
I have the MSD 8.5mm Super Conductor wires and the NGK Iridium TR55IX's and they are great!!! Not sure about cleaning the TB w/out removing it.1988 Firebird 2.8L (Black Pearl): <br />New interor & paint<br /><br />2001 Firebird 3.8L (Pewter):<br />!MAF; SLP CAI; K&N; SLP LoudMouth; DIS-4+; Blaster Coils; NGK TR55IX\'s; 8.5mm MSD Wires; Jet Stage II; TransGo; Corvette Servo; Addco STB
New air filter. If you don't already have K&N or Airhog, get one. [img]smile.gif[/img]
Check your serpentine belt to see if the ribs are splitting or it's worn.
Some people also like to run seafoam through their engines. I did this and it burned off a lot of carbon. Better outside of the engine than inside. :D1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
That might be a remote possibility. I didn't have any trouble running seafoam on my 170K mile engine though. No leaks.1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
Fuel filter, change oil/filter, coolant flush.. all VERY important.2004 CE Corvette 10.86@132mph
2011 Cadillac CTS-V
2006 Mitsubishi Eclipse GS
everything that has been said so far. and at the begining of the post you said that you were going to have it done, right? everything that has been listed is very easy to do (plugs and wires are a pain, but not hard), you should do it yourself. also, you might consider changing the oil in the diff. and changing the trans fluid.2000 pewter firebird<br />Short Throw Shifter, Whisper Lid, Whisper Ram Air, Holley Filter, B&B Triflo, LSD, BMR LCA, STB, PHR, and sway bars (32/21).<br />Power window conversion
ok this is my plans as of right now, i have a goos chunk of change to spend and well mostly on appearance i am also getting sutff done i need:
coolant flush: 20.00
tuneup: 40.00 + parts (i am buying msd wires,ngk or bosch plugs, and the pcv valve, and fuel filter)
rims and tires: 1200.00
balanced and front end alignment: 50.00
transmission service:60.00
and if i have enough money i am gonna buy an SS hood: 600+
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...7 hours ago
