I have a 95 3.8 and a week ago I sprung a oil leak from the point from where the wire harness connects into (what I understand to be the oil pressure regulator valve) so I replaced the regulator valve (cylinder thing with a plug on one end) and now when I first start up my car my gauge reads about 110psi then after the engine warms up to about 180 degrees it drops down to 90 psi driving and 55-60 psi idling. in my understanding I need to replace the oil pressure sending unit which would be the wiring harness am I correct. Thanks for any help.
NEED HELP OIL PRESSURE 110
http://home.cfl.rr.com/mkaprocki/Camaro/L36.bmp
Did you change #7? That is the Oil Pressure Sensor.
To change the Oil Pressure Relief Valve you have to remove the filter and the part the filter screws onto.Matt
1998 Mystic Teal Camaro M5
If the oil pressure wasn't showing that high before you worked on it, I'd bet there's a problem with the sensor.Matt
Is there any way to test the sensor or do I just buy a new one. The old leaking sensor was reading at 35-40psi which is low, compared to when I was running at 60psi before the leak, also I was low on oil while running at 35psi.95 firebird a4 <br />slp cai, borla exhaust, trans go shift kit, corvette servo
I've just installed a second oil sending unit and still no diffrence I also changed the oil and filter. While I was under the car from the passanger side I saw a wet spot on the rear passanger side of the engine just above where the tranny and engine connect behind the silver circle I think that is an oil seal. Any other suggestions would help thanks95 firebird a4 <br />slp cai, borla exhaust, trans go shift kit, corvette servo
I finally got it taken care of it was the oil pressure sending unit, but it was Advanced auto who gave me the wrong sending unit twice so now Iam out 40 for the two switches plus the 80 I paid the mechanic. Anyone else have a problem from them giving you the wrong part.95 firebird a4 <br />slp cai, borla exhaust, trans go shift kit, corvette servo
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...11 hours ago
