whats thebest fuel injector cleaner? - FirebirdV6.com/CamaroV6.com Message Board
  • whats thebest fuel injector cleaner?
    im plaining to get a tune up latter but for now i just wanna use this to hold me for a while. i think i used stp before, and it was ok i noticed a little differnce. i think the best bet wouldbe lucaus but i dunno.
    JpX
    Re: whats thebest fuel injector cleaner?
    i & another member dont think they work
    but i like seafoam & B12 Chemtool
    I'm sure theres some professional stuff
      two questions:
      1. where can i get this stuff? or do i have to order it?
      2. where exactly do i pour it?
      JpX
        You can get the stuff at autzone! I just used the B12 stuff! Its called Berrymans B12 and you just pour it into your gas tank whenever you fill your car back up! I suggest using two and it will give your engine a good cleansing! Its works too!
          thanks
          JpX
            Trust me, all that stuff is a waste of money. I used every kind i could find, thats about 6, and i even used seafoam both on my intake and gas. After all this i noticed my intake manifold was leaking coolant, i had to take the whole top of the engine off. When doing i took note of every thing. #1 my intake was feaking nasty, i had to soak it in carb cleaner over night. #2 my injectors where filthy, i had sprayed both ends with carb cleaner and used a cotton cloth, and qtips to clean them. When i was finished i throw my egr valve in the trash and my car runs like brand new with my hand cleaned injectors.
              check out the pic and you tell me. all the holes were nearly clogged
                2 days ago
              • Doodler
                97 Camaro base with expensive sounding noises
                by Doodler
                Still trying to find oil leak
