Is there any way to turn the interior lights off when the door is opened ?
Is there any fuse i can remove or a wire i can put a swich between ?
Anything I can do ?
And NO, I dont want to remove the bulbs ;)
<i><b><br />1995 Convertible - - JUICED <br />There´s a difference between living and being alive - <a href=\"http://members.inode.at/christian.pichler\" target=\"_blank\">www.CLC1.de</a></b></i>
On my 96 my dome lights would come on at random times. I believe it is the Body Control Module, replace it next week. Anyways, I pulled the fuse that was labled courtesy and the dome light no longer worked but all dash stuff was still good. Hope this helps you
yeah, pulling the fuse will definitely turn them off, I also had the random courtesy lights staying on. Eventually they just stopped and I havent had any problems since.
