I was looking to install the MSD DIS4 Ignition unit. I read thru the directions and the online guide, but the picture cut off and I couldn't see where (and how) they actually mounted the control unit. Do you route the fuel lines over or behind the unit? Do you have to create any special bracket for the unit? Do you have to move the fuse box? I just want to make sure the unit clears the hood, fuel lines, wires and anything else that might get in the way.
-Paul
This belongs more in the genral tech forum. Anyways I put mine next to the fuse holder and just screwed that sucker in. If you have the original hood on it should clear it mine did. The fuel lines, they just go over, havent found a way to move them out the way though. But you can find a better way to put them. I myself have installed a ram hood and the box is not making the hood sit right on that side but owell. If you have trouble hooking it up let me know. It was a pain for me till I did a little research. Also If you do your in a cool diffrent way let me know. I want to move mine, maybe under the steering wheel inside.
