My car wont start...help!!! - FirebirdV6.com/CamaroV6.com Message Board
  • My car wont start...help!!!
    It's not my firebird, but my 1995 chevy corsica.
    All the lights work...
    but when i go to start it cranks for a bit but doesn't turn over.
    what could it be?
    If it's cranking strong, my first guess is your fuel pump. Time to get a chiltons book and get crackin.
    2000 Firebird 3.8, auto, flowmaster 80, taillight blackouts, 02 formula swaybars, poly endlinks and energy support bushings, 1 1/2in cut springs
      just to make sure, check that all your inition/injector fuses are in good condition. Maybe disconnect the fuel filter from the line, and put a bucket under the line and turn the key to the on position to make sure you have pressure through the lines. Check to make sure you have spark coming from each spark plug wire. How did it stop running? Might also check your timing gears. I had a cracked crankshaft gear that cause my timing to be thrown off so much it wouldn't run any longer. hope you get it fixed. Derek
      160* thermostat, K&N cold air intake, pullies, red lights inside air condition vents, ZO6 17\"18\"back. Black letters inside fire red CAMARO lettering. (used electrical tape) Anyone know cheap mods? Still a student
        2 days ago
      • Doodler
        97 Camaro base with expensive sounding noises
        by Doodler
        Still trying to find oil leak
