I had trouble starting my 96 camaro this morning. I went out to start the car and turn the key and nothing not even a click or a try to start. Everything was lite up so there was plenty of power. The two things that I did notice were that the red secrity light was blinking and the orange sercurity symbol was lite up on the gage cluster. I disconected the battery and left it for twenty min. and reconnected and the same results. I think it could have to do with the security system or the chip reader that reads the key is going. This has happend once before and after a while it started. Any ideas?
Car Wont Start!
Re: Car Wont Start!
Clean your key thoroughly with rubbing alcohol, and spray a short shot of electrical contact cleaner into the ignition lock. You can get it at any Radio Shack.95Camaro3.4T5Conv Red/White*SLP Bilsteins*BMR Tower Brace*CAI*NiehoffIgn*NGK PlatPlugs*DelcoHiPerfWires*FlowmasterCatback*RedDe vilReso(no cat)* DynoMax Muffler*B & M Shifter*Eurolite Lamps*Yokohama Avid 235/55/16*GM 3.73s*Auburn LSD*Sirius*All DONE!
Re: Car Wont Start!
sounds pretty dead on with you needing a new lock cylinder. try what Publican said but if that doesnt work, take it to a dealer to be checked out.
Re: Car Wont Start!
well I got the car started. I disconnected the computer connections and saw epoxy dust so I spraied electrical cleaner and reconnected nothing. Did it agian to see what wire goes to the key to connect a volt meter to see if it is sending power to eliminate that, and it started go figure.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...6 hours ago
