anyone here use the washable oil filter from pure power? saw it reviewed in hot rod magazine, so i checked it out on the web. $200.00 for an oil filter ($90.00 for a fuel filter) is steep, but you can disassemble it and clean it and reuse. would pay for its self over time, and you can use it to help keep an eye on metal shaving and what not in your oil.
pure power oil filter
Re: pure power oil filter
they use a fine metal screen, but in my mind they will never filter as well as a paper filter. My yamaha ttr250 dirt bike has one, and no one makes a paper one for it. Again, i would not use it even if it was the same price as a delco filter.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
I think my grandad had one on his corn binder in 1933. Don't think the technology has changed much since.95Camaro3.4T5Conv Red/White*SLP Bilsteins*BMR Tower Brace*CAI*NiehoffIgn*NGK PlatPlugs*DelcoHiPerfWires*FlowmasterCatback*RedDe vilReso(no cat)* DynoMax Muffler*B & M Shifter*Eurolite Lamps*Yokohama Avid 235/55/16*GM 3.73s*Auburn LSD*Sirius*All DONE!
In normal driving it would take about 16 years of use to be worth it economically over the proven $3 acdelco filter.\'00 f-bird 3.8 M5 coupe, pewter metallic<br />Torsen LSD, Pro 5.0 shifter, Spec stage 1 clutch, Y87 muffler, aftermarket stereo<br />-more fun than the Oldsmobile it replaced...
^^^ Math rocks! :DDrivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
