I have never seen the inside of a fuel injection system and not quite sure how it is set up but would a leaky oring on one injector cause both banks to run lean or is it just limited to the bank the injector is located.
Thanks in advance
Modifications:<br />headers, throtle bod spacer, flowmaster, high flow magnaflow carsound cat, powerdyne sc with 2.9\" pulley and by-pass valve, walboro 255 fuel pump, spec stage 2 clutch, and HP Tuners
my guess is only one side, since there are 2 main fuel lines that go to the rail.
you can get orings from oreillys for $3. I've had to replace one of mine after it completely broke. IM NO EXPERT though
Thanks in advance
A leaking injector o-ring would tend to run only its bank lean.
