i have a 3.4L and i want to take out my ac since the clutch seems to engage on its own and my car weighs enough as it is it wont miss a few pounds has anyone done this or have pictures or advice ? can i just take it out and get a shorter belt or is a replacemnt pulley involved
has anyone done an ac elimination
Re: has anyone done an ac elimination
i removed my ac, but left the compressor in for the time being
I'm not sure if you'd have to get the idler braket or not, i dont have a 3.4
and I dont even know if I have to get an idler for my 3.8
its easy, straight forward... just rip it out ;)2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
I removed the whole AC unit from my Firebird, and I did buy an AC delete bracket. There are some availiable for both the 2.4l and the 3.8l, but from what I can tell they come from two seperate people.1995 Pontiac Firebird
you might want to take it to a shop to get them to vent the freon..otherwise you'll vent it into the ozone and that will cause little baby seals to die2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Originally posted by slow6that will cause little baby seals to die<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
ya, i know you leak your freon out into the atmosphere
so do I, but I just did it once ;)2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
you can run a shorter belt. i can't remember what length i used, but i was running a shorter belt to bypass my compressor before i brought it in to get fixed. if you have time, you can go to an auto parts store and buy a few different sizes and just use trial and error. or, loop a rope around the projected path to bypass the compressor and measure the length. i didn't have much time, so i dropped it off to my mechanic and he threw a new one on (somewhere around 62" i THINK). the belt worked for a few months then snapped...i don't think the belt was the highest quality b/c the tension of the belt seemed fine. still, its something to consider. i don't believe you can use a belt from a non-a/c 3.4L car because i think they might have an idler pulley.i\'m not an ambiturner.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...21 hours ago
