How does that work. I've noticed that is does not come on after 3,000 miles. My dad has a Cady STS and what his car does is test the oil and tell him how much life is left. When it gets time to change it, the oil light comes on. Just wondering if our cars do the same.
Change Oil Light
As I understand it, the oil is not tested as some think. What the monitor keeps tract of is miles and speed. In other words, a car that is driven in city stop and go traffic will need to have the oil changed more frequently than a car driven at normal highway speeds and under light load. What the monitor tries to balance is miles and engine load.
In any case, under "normal" driving circumstance the oil and filter should be changed somewhere between 3,000 and 3,500 miles unless the engine is operated under heavy load and then the oil and filter should be changed before 3,000 miles.
Some will argue that synthetics hold up for a much longer interval, even under heavy engine loads, than regular oils, but no one can seem to put a number on the difference between the two types of oil and prove it. The proof may be there, but I have not been able to find it.
That is the way it was explained to me by a GM tech.2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
"What the monitor keeps tract of is miles and speed."
I think it also counts engine starts or maybe just cold starts. It would be interesting to know the exact equation it uses. In any event, mine seems to come on between 5-7K miles.2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
<blockquote>quote:</font><hr>Originally posted by V6Bob:
I think it also counts engine starts or maybe just cold starts. It would be interesting to know the exact equation it uses. In any event, mine seems to come on between 5-7K miles.<hr></blockquote>
Do you have the oversiezed oil filter?
Because since i got the biger filter my light doesen't come on until around 5500-6500 miles.~S87 Black 99 Firebird~
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...13 hours ago
