ok so I took the EGR valve apart to try and clean it since everyone said I had a stuck valve. never know how one worked till now. so I cleaned the 3 valves with carb cleaner and a razor blade. put everything back and went for a drive. didn't fix my problem still getting a code after driving highway speed and then let off the gas.:(
