hey I gotta question...It might seem simple, but I have a 2001 camaro and I cant cut my car on without my headlights coming on at night. Is there a way to do this??
headlights
Re: headlights
if you use the search feature, then you will find your answer http://www.xse.com/leres/ss/drl.html there it is in short
Re: headlights
theres a much easier way to get around this...
im assuming you want to control your lights with the knob...
put your parking brake up on the lowest notch, it shouldnt be engaged at all
you have to do this before you turn the car on, and you must be sure the parking "brake" light is onWhite 1998 3.8L Camaro
Home Ram Air / Free Flow Intake
Drilled / Slotted Rotors with black painted Calipers
Re: headlights
Re: headlights
Im sure if there is a lock there to hold the parking brake, then there is contact. I would recommend you go the other way. also, this isnt just a canadian car thing, its all f-bodies
Re: headlights
I think so yes. do you not have the little black ball sticking out of your dash vent area? if not, the sensor is there but i wonder if your BCM needs to be tweeked to recognize the system. i know with a tech 2, you can change the BCM options which i would guess this would be one of them
Re: headlights
pull out the radio and you'll see the sensor, just disconnect it; not all that hard takes maybe 10mins to do (i did it on my car)1995 Black Firebird Turbo 3.8L<br />Custom FS Headers | AiResearch T04B | Tial 38mm | Bosch BOV | 30\" FMIC | 2.75\" IC pipes | 3\" Exhaust w/cutout | Flowmaster 80 | Walbro In-Tank 255LPH | 180* termo | Autometer Boost + A/F (phantom) | 36# GTP injectors
Re: headlights
well blldogg, i took of that dash piece and found where the sensor should be, but no obvious wiring harness, if you wouldnt mind this would be a pretty good research project for you, considering you do have all the resources (diagrams etc...) just see what you can come up with
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...21 hours ago
