Flushed radiator, but only used 4 quarts... - FirebirdV6.com/CamaroV6.com Message Board
  • Flushed radiator, but only used 4 quarts...
    Ok, I drained and used that Prestone flush kit. I drained it from the bottom of the radiator and when I did everything I only used 4 quarts (1gal) of the green Supertech 50/50 coolant. I ran it for ten min and yurned on the heater and still had no room to fill anymore, I also put 12 capfuls of water wetter. I was going to use the whole bottle, but I COULD'NT GET IT IN.
    Did I do everything right?
    K&N FIPK, Pacesetter Headers, Carsound Highflow Cat, 3\" Magnaflow catback, 180 Thermostat, 8.5 MSD Wires, NGK Plugs, Chrome ZR1 Rims
    Re: Flushed radiator, but only used 4 quarts...
    The engine block still has coolant in the coolant passages. It would probably be best for a pro to flush it out cause they use pressure. I would flush it alot just to be safe. Its cool that you're using the flush kit.
    Turning on the heater by itself is only going to turn on the heater fan, its not gonna move the water around in the block. I guess if you had an air compressor and had some way of hooking it up that'd be cool. I'm no expert.
      did you forget about the heater core??????
        yea, of course, the heater core and lines still have coolant in them, and there are a few other lines i can think of
          While you ran the heater you did open the air bleeder valve on the water neck didn't you? You need get to get all that air out.
          95 Camaro 3.8L Y2K motor <br /><a href=\"http://www.cardomain.com/id/coriya71\" target=\"_blank\">www.cardomain.com/id/coriya71</a>
