When replacing the Idle Air Control Valve is there any adjusting that needs to be done before putting the new one in? I was about to put my new one on and figured I'd ask first.
IAC valve replacement help
I went to change this thing this morning and I can't figure out how to get the 2 screws/bolts out. They look like Hex screws but are rounded out. I tried every size socket I could think of and none worked either. Can someone confirm if what I need to get these things out? Thanks<a href=\"http://www.cardomain.com/ride/2093533\" target=\"_blank\">CarDomain Page</a>
I know the MAP sensor uses a Torx head and I'm pretty sure the IAC is the same, although I don't know for sure offhand.Matt
1998 Mystic Teal Camaro M5
