IAC valve replacement help - FirebirdV6.com/CamaroV6.com Message Board
  • IAC valve replacement help
    When replacing the Idle Air Control Valve is there any adjusting that needs to be done before putting the new one in? I was about to put my new one on and figured I'd ask first.
    <a href=\"http://www.cardomain.com/ride/2093533\" target=\"_blank\">CarDomain Page</a>
    Nope, just plug-n-play ;)
      I went to change this thing this morning and I can't figure out how to get the 2 screws/bolts out. They look like Hex screws but are rounded out. I tried every size socket I could think of and none worked either. Can someone confirm if what I need to get these things out? Thanks
        If allens don't work it's probably a torx. I'd have to see it to be sure.
        1999 Y87 Camaro<br />Whisper Lid, SLP SS Takeoff Exhaust
          I haven't had another chance to take a look at this. Does anyone know what's needed to get this off?
            I know the MAP sensor uses a Torx head and I'm pretty sure the IAC is the same, although I don't know for sure offhand.
            Matt
            1998 Mystic Teal Camaro M5
            • 187shark
              by 187shark
