Anyways, I left a post here about failing smog check. I switched out the front two and rear O2 sensors and the SES light is still lit. I don't know what else to check. Switched out the air filter, changed my oil about a month ago along with the filter. Some guy checked out my fuel pump pressure and he said it's good, so now I don't know what to do. Also when I floor my car in 2nd gear around 4000 rpms my car seems to be sluggish, like you can feel a loss of power for a split second then it continues to kick again. So I'm not so sure what to do. Any help will be great. Thank you in advance.
Sluggish power
Re: Sluggish power
have you ran a scanner to see what the code is that you are tripping?
Re: Sluggish power
...or unplug the battery for 30mins. so that the Ltft/Stft data will be erased and the new o2s can re-learn2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: Sluggish power
Yeah the code is still P01714 and P0174 system too lean on bank one and two. Also, before I switched out the O2 sensors we unplugged the negative and replugged it afterwards.
How do you go about erasing the code? What do I need to get to do that?
Re: Sluggish power
Originally posted by slow6...or unplug the battery for 30mins.2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: Sluggish power
Yeah, it came back. I drove around for a while because normally when I take it to smog check without driving around for a while, the computer will come back not ready. They would normally tell me to drive it around some more for the computer to restart.
Re: Sluggish power
"Also when I floor my car in 2nd gear around 4000 rpms my car seems to be sluggish, like you can feel a loss of power for a split second then it continues to kick again"-----bad cat maybe???? mine was doin something identical to that\"there are things known, and things unknown, and inbetween are the doors\"-jim morrison<br /><br /> <a href=\"http://www.cardomain.com/id/99NBMCamaro\" target=\"_blank\">http://www.cardomain.com/id/99NBMCamaro</a>
Re: Sluggish power
ebay
dont spend more than like $40 on a catco high-flow cat
or you can just gut yours2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: Sluggish power
I was also having all these symptoms on my '00 camaro. Slugish power, sometimes rough idleing, and the same OBD codes. I was thinking about doing all those tune ups (O2 sensors and such) but just changed out the fuel filter and had a Fuel system clean (by Midas) and that fixed everything. My fuel pressure was fine and my O2 sensors were fine. If you still have some problems it may just be that your fuel injectors are clogged/dirty.
Re: Sluggish power
bobby doesnt think store bought fuel injectors work2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: Sluggish power
I also used the fuel system cleaners but they never worked. I did the full fuel system cleaning and it got rid of the OBD codes are have never came back. All the low end "lag" is also gone. You might not get the same experience and may not fix your problem, but it sounded so similar to my situation I thought maybe you can give it a try. But it's up to you:tup: :)
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...8 hours ago
