Is it possible to put gear drive in my 95 z-28???
Gear Drive
In your 95 Z??
I don't know of any LT1's running gear drive just yet. I do think you can do double timing chain setup though.Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
they make one for the 93-02 Z28, its quieter than other gear drives. i think pete jackson (brand) makes it. check out www.summitracing.com - i think thats where i saw it.
hybrid - \'\'hI-br&d - The offspring of a cross between species.
Co-Founder West Coast F-Bodies
West Coast F-Bodies Car Club - WCFB Message Board
<blockquote>quote:</font><hr>Originally posted by camar0guy:
Some say that i cant go with gear drive becasue of the knock sensor.> They say it will detect various knock?<hr></blockquote>Gears don't knock, they whine. If you are getting a knock, you installed it wrong or the timing cover is bent.\'94 Camaro 3.4<br />\"No, Starvin Marvin. That\'s my pot pie.\"
And I'm 98% sure I've seen them that will work for you, at various noise levels. Meaning you can get one that barely whistles at all, up to one that whines like a blower. To those that don't know, this doesn't replace the timing chain, it is still necessary, it simply helps it run more efficiently. It goes right between the cam and crank gears, and costs around $100.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
