drop k-member to take motor out via underneath - FirebirdV6.com/CamaroV6.com Message Board
  • drop k-member to take motor out via underneath
    Anyone know which bolts I need to take off to remove my K-member so I can pull the engine out from underneath the car?
    I'm sure no one knows so I might take the engine out the regular way which is *supposedly* harder to do but I dont care. Thats the only way I've done it before.
    thanks
    Re: drop k-member to take motor out via underneath
    the Haynes says that """"you cant drop the k-member and pull the engine out from underneath the vehicle because a home mechanic has no safe way to raise the vehicle High Enough to utilize this method of removal.""""
    Couldnt I just hook up my engine hoist/cherry picker/engine lift to the frame of the vehicle to raise the vehicle? is that not safe? Could my 2-ton engine lift not get my car "High Enough"? I cant see why this method is refered to as Unsafe. The Haynes says the only safe way is to have a garage-type lift which I have not. I wish I could trade it in for a Chilton's.
      do you have a garage? hook up a pully system to the top of it to lift the frame.
      95 Firebird<br /> <a href=\"http://www.cardomain.com/memberpage/673250\" target=\"_blank\">http://www.cardomain.com/memberpage/673250</a> <br /> <a href=\"http://photobucket.com/albums/y217/andrewbrandon19/\" target=\"_blank\">http://photobucket.com/albums/y217/andrewbrandon19/</a> <br /><br />me on a good day------&gt; <a href=\"http://communicatio.webblogg.se/images/wet_cat_113159625.jpg\" target=\"_blank\">linky</a>
        just gonna try to use a engine lift to the frame
          actually, I just got done pulling the motor from Above by myself. lots of fun
          but glad its out, now its time to strip it apart
            i have a feeling without a lift its just a bad idea....
              i think taking it out the top was easy enough, didnt need to drop the k-member
