i think my starter is going up on me. more and more reccently the car is having a hard time starting up i already had the wires and plugs checked so this is making me think its the starter. does anyone know how much would be? or where i can get one cheap?
starter question
Re: starter question
probably $250 or so?
my class mate had a starter problem but the mechanic he got towed to, i think he knew him, fixed it for 70 bucks instead.
plus an auto shop teacher i had said usually the only thing that goes bad on a starter is the points, whatever that is, which can be replaced for not much-RJ \"Like trail mix I\'m a lil sweet but mostly nutty\"<br />Metallic Blue 2001 3.8 Firebird M5<br />FRA,Smoothed Air lid, Homedepot Intake, K&N Air Filter, MSD Coils & Plug wires, Iridium Plugs, Flash Tune, 2.5 Flowmaster Catback.
some starters are NON-servicable.
Oreillys has starters for like $110?
Its only 2 freaking bolts that are easy to get to come on. Dont take
it to a shop to get them to do it. It takes like 15 minutes, but you'll need an extension.2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Originally posted by Jpx87i think my starter is going up on me. more and more reccently the car is having a hard time starting up
Not sure if you are aware or not, but if the engine is cranking at a normal speed, the starter should be fine. Just checking though...sigpic
Originally posted by hockeymanIs the engine cranking or is the starter cutting on/off when the key is turned?
reccently when ive turned the key it makes that "click" noise when the engine is trying to fire up but it keeps making that noise instead of firing up so i turn the key back and try it again and it fires up. also it has been taking a longer amount of time to fire up so its clicking for logner periods of time. also today when i went to fire it up it started clicking paused (made no real noise) the suddenly i herd it fire up. so thats why im guessing its that ill take any suggestions.JpX
maybe if its just clicking its not getting enough power? do you have a system?2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Originally posted by slow6maybe if its just clicking its not getting enough power? do you have a system?
not sure what system your talking about the car is basically stock so if it was a aftermarket thing then no.JpX
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...4 weeks ago
