Please Help No Start !!!!!!!!!!! - FirebirdV6.com/CamaroV6.com Message Board
  • Please Help No Start !!!!!!!!!!!
    I was out in the driver way wirting down some voltage numbers from my boost guage so i can make it work in HP Tuners
    well i was reviing it so i could see 18-20 Vac.... and it spiked to ~12 psi (foot must have been moving and i didn't know... i let off the gas and the car stalled and will not restart
    CHECKED:
    1. oil looks fine
    2. no leaks under car
    3. #4 rocker arm still move when cranking (timing chain check lol)
    4. took out #1 plug wire. held to ground with good spark
    5. took out #5 plug agian it looks fine
    6. fuel pump primes to ~47 psi
    7. car cranks over ~200 RPM but will not start nor doe it try
    8. AFR during 12 psi was ~10:1 (HPT log)
    9. Timing advance was ~15*
    10. check all fuse's
    Hear a "click sound" when cranking sounds like a sprak arching
    no mecanichal nose
    one thing even after much cranking the plugs are not fuel soaked what would shut off the injecotrs like that?
    www.turbov6camaro.com
    1997 3800 Series II Camaro
    Re: Please Help No Start !!!!!!!!!!!
    Security System?
    VATS/PASSKEY shuts off fuel, but it will still crank and everything will look right.
      Originally posted by Nachius
      Security System?
      but would it shut the car off from a running state?
        NO not that I know of, but if I different issue caused it to die, and then the VATS/PASSKEY kicked on it definitely wouldn't start.
          vaccum leak? clogged fuel line? electrical short somewhere? battery/alternator? starter?
          1995 Black Firebird Turbo 3.8L<br />Custom FS Headers | AiResearch T04B | Tial 38mm | Bosch BOV | 30\" FMIC | 2.75\" IC pipes | 3\" Exhaust w/cutout | Flowmaster 80 | Walbro In-Tank 255LPH | 180* termo | Autometer Boost + A/F (phantom) | 36# GTP injectors
            motor is gone no comperssion on #5 :( :( :( :(
              That is so not good
                have you found out if its valves? rings? or H/G? yet?
                you need some chrome moly rings and valves lol
                if you lived closer I'd help ya
