whats the big difference between 7.5mm plug wires and 8.5 and also will msd coil pakcs make a big difference in a stock engine??
spark plug wires
Re: spark plug wires
Originally posted by camaroz87whats the big difference between 7.5mm plug wires and 8.5 and also will msd coil pakcs make a big difference in a stock engine??
from what i have heard changing coil packs really makes no difference... but dont quote me on it.
If i were you, i would just get 8mm plug wires... they are usually the standard
the only difference is less resistance, so better performance. no, you really will not notice any difference replacing the coil packs.
MSD coils will make no change in performance on a stock engine.
by Need4CamaroThe panel under the HVAC controls where the button is supposed to be is completely missing when I bought the car so I dont know if this car had TCS or...3 weeks ago
by Need4CamaroI was wondering, are these cars DBC or DBW?
If swapping in an LS motor (lets ignore the rest of the complexity of the swap), what would be...3 weeks ago
