This has me a bit confused. My right blinker will sometimes light up and not blink... It usually works fine if im at a cruising speed, but if im stopped it wont work, it just lights up. Could I be out of blinker fluid?(LOL j/k i saw that in someone's sig... thought it was too funny) I am thinking it is a short, but where should i start to look, i hate taking apart the lights, and i just fixed it... Also the plastic on the bottom of the light hits a piece of metal every time i close it... could that be the problem? Thanks in advance!
Blinker Problem
Sounds similar to a problem that I had. Have someone get in the car and hit the brakes for you. Check to see if your running lights/turn signals glow a little (don't turn on signals for this). If they do glow I believe it is your ground that might be the problem. The ground is located in the trunk, under the carpet, behind the trunk lock.98 Silver Camaro V6<br />15.238 @91.74 w/ 2.288 60\'<br />Mods: K&N, FTRA, Pacesetter Headers, Spec 3 Clutch, 160 Thermo, TSP Rumbler, 3\" Catco, Whisper Lid, 3.42\'s w/LSD, Aluminum DS, Man Fan Switch<br /><br /> <a href=\"http://www.cardomain
Yeah it sound's like low blinker fluid to me.... [img]graemlins/rofl.gif[/img] I'd replace the bulbs, check the ground, and go from there..2000 Firebird. Whisper Lid, True duals, TSP mail order tune, Built Tranny , TCI 2800 stall verter, B&M tranny cooler, Eaton LSD, 3.42 gears. Current best ET. 15.232 89.09 MPH 2.175 60ft on stock 3.42\'s and open diff.<a href=\"http://www.geocities.c
Ok, its not the ground, the signal lights didnt glow. Although there are several wires around the lock, all seemed to be fine.1995 3.4L A4 Firebird White w/T-Tops *SOLD*<br />**NEW CAR**<br />2004 White Cavalier Coupe<br />2.2l ECOtec 5 speed
Replace the signal bulbs and your lights will blink again. I had to replace the daytime running lights on my bird and the blinking worked again.
The factory has the lights set up so if one of your lights go out, your turn signal stays on and wonk blink.New Toy Red 94 Formula LT1
RT: .0006 60': 1.894 1/8 mile: 8.351 @ 84.89 1/4 mile: 12.974 @ 107.81
crashed Red 96 Camaro 3.8l: 14.91 @ 92.38
The ex wife's Black 98 Firebird 3.8l: 15.23 @ 88.12
yeah my daytime running lights burn out every 2 weeks :mad:www.turbov6camaro.com
1997 3800 Series II Camaro
My DRLs used to burn out every 5 days, but I finally found the problem. There was a small pool of water inside the lens so everytime the water hit the hot bulb, it would explode. I has to replace both lenses and now they are great. Actually, with the new lenses, the DRLs are brighter.New Toy Red 94 Formula LT1
were you get the ne lens at?www.turbov6camaro.com
I bought mine from this website
http://www.headlightswholesale.com/p...nal-light.htmlNew Toy Red 94 Formula LT1
my camaro does that but with my left blinker, it dont do it all the time just about one out of ten times i use my blinker1997 Camaro RS<br /><br />3\" Flowmaster Exhaust,Pacesetter headers,Catco Cat,Cold Air Intake,Clear bumper lights altezzas,chrome rear bumper letters,chrome badges, headlight conversion kit(soon to come),2 12 MTX Thunder 8000, MTX 6500d amp, Fosgate 1 farad cap
ok...this sounds somewhat like my problem...my right side drl lights up when my headlights are on at nite, otherwise, its off. when i put on my right turn signal, the green arrow on the inside stays on. the left side of the car works fine...it was crappy when a cop was following me and i needed to make a right turn but didnt wanna get in trouble for no turn signal, so i had to keep making left turns...lol...any ideas what i need to do?Bada Bing...
Mine hasn't done it in a while now. I checked the wires by the hatch lock and it started working fine. Must have been a loose one or something, but it isn't doing it anymore.1995 3.4L A4 Firebird White w/T-Tops *SOLD*<br />**NEW CAR**<br />2004 White Cavalier Coupe<br />2.2l ECOtec 5 speed
well, my right blinker wouldnt blink, it'd just be 'on' anyway, u need a new relay for it, cost $7 CDn... remove the panel under the steering wheel, its on the right...97 camaro<br />black, 5 speed, t-tops, rockford fosgate cd w/4X6.5\" rockford speakers, 3\" flowmaster american thunder catback with 3\" carsound cat, SLP CAI, B&M Ripper w/leather Hurst shift knob, 5% tint.<br /> <a href=\"http://camaroz28.cardomain.com/id/ianwells100\" target=\"_blank\">http://camaroz28.cardomain.com/id/ianwells100</a>
by ssms5411So my truck is finally getting some work done, after 17 years, Oil pressure sensor went out and it’s located under the lower intake manifold. Have to...19 hours ago
