Whistling Noise - FirebirdV6.com/CamaroV6.com Message Board
Whistling Noise
  • Whistling Noise
    My car makes this noise at idle like a whistle, but not as high pitched. I noticed it while at a drive thru. What should I look at? Thanks,
    John
    Did you just turn your A/C off when you pulled up to the drive-through?
    1997 Camaro RS A4 <br />3.08 Rear<br /><a href=\"http://www.cardomain.com/memberpage/470169\" target=\"_blank\">http://www.cardomain.com/memberpage/470169</a><p>Mods:<br />SLP Cold Air Intake<br />Flowmaster 80 Series Muffler <br />MSD Ignition Coils<p>Soon to be installed:<br />3.42 Gears<br />MSD Plug Wires
      Check for vacuum leaks.
      99 Dodge Quadcab<br />Traded: 2001 Camaro(will be missed)<p>Be wary of anything that can bleed for 5 days and live....
        maybe you have a turbo and didnt know it?
        is your radio on when you hear the noise?
          Thanks for the replies.
          The AC wasnt on and hadnt been on.
          The radio was off and doesnt give me noise anyway.
          The vacuum leaks might be the prob, seeing as I also have fuel problems and, correct me if I am wrong, the fuel pressure regulator is controlled by a vacuum line. Any thoughts? Thanks.
            Could be a serpentine belt too. When mine was bad it was making a whining sound.
            1996 BLack Camaro 3.8L V6 w/ Flowmaster 80 series, NGK plugs, SLP CAI, custom ram air mod, 600watt Kenwood and 2 10\' JL audio subs.
