I have just recently encountered a problem with jerking when I press the accelerator especially when around 50 mph and going up hills. The car runs fine except when any of the two conditions on top are met. I feels like there might be some gas obstruction but I have changed the fuel filter and the problem is still there. Has anyone encountered this problem before?
Problems with jerking when accelerating
Re: Problems with jerking when accelerating
I had those issues....but also had a bad idle...burnt plug wire boot to cylinder 3 was my issue.30th Anniversary Camaro<br />White with platinum pearl w/metallic midnite blue racing stripes.<br />SLP CAI, Flowmaster exhaust, Taylor wires, NGK\'s, Streetglow Undercar neon (blue)<br /> <a href=\"http://www.cardomain.com/ride/1352101\" target=\"_blank\">http://www.cardomain.com/ride/1352101</a>
I just fixed that problem on mine. I went through all the "cheap" things that might fix it....plugs, wires, etc. Turned out to be a clogged catalytic converter.2000 3.8L Firebird, Silver Metallic<br /><br />\"Yes, London. You know, fish, chips, cup o\' tea, bad food, worse weather, Mary f***in\' Poppins, London!!\"
Originally posted by memphis_rainesI just fixed that problem on mine. I went through all the "cheap" things that might fix it....plugs, wires, etc. Turned out to be a clogged catalytic converter.
how did you find out that your cat was clogged?, mine is kinda rusty and rattles a tiny bit, if your cat is clogged does it give a code?
cat code yes2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Originally posted by fgbird96I have just recently encountered a problem with jerking when I press the accelerator especially when around 50 mph and going up hills. The car runs fine except when any of the two conditions on top are met. I feels like there might be some gas obstruction but I have changed the fuel filter and the problem is still there. Has anyone encountered this problem before?
