I just purchased a 2000 Chevy Camaro 3.8L V6 and I need some basic starting mods I can add? And also, what do I use to clean under the hood?
Any Suggestions?
Re: Any Suggestions?
Engine Degresser!
*But after you are done you have to make sure you lube your belt and other rubber stuff, or at least they recomended it because it hurts rubber pieces.
Other than that take a few looks, good common starts are Cold air intakes, hot plugs, wires, ignition coils, exhaust systems, low temp thermistats, chips or get a programmer, and then always the much craved suspension and brake upgrades of course.
All depends on how far you want to take it.1995 Camaro 3.4 A4<br /><br />CAI,IAT Relocate
Welcome! :wavey: Where are you in DC?
I would do a basic tune up first to make sure everything on the car is up to spec then start modding.
Good first mods are cold air intake, lid, filter, high flow cat, and cat back exhaust. If you want to do suspension go with LCAs, subframe connectors, shocks, springs, LSD, gears, and last but not least nice tires.
