A response to the difference between a 93 & 94 Z28 - FirebirdV6.com/CamaroV6.com Message Board
  • A response to the difference between a 93 & 94 Z28
    I saw that the topic was closed and wanted to clarify that there IS a difference....
    the 93 has a speed density sensor which makes tuning them so much harder. The PCM cannot adjust for A/F changes....
    The 94 has a MAF which makes life a whole lot easier to tune since THE PCM can regulate and adjust to modest changes in A/F
    Also the trans are different......
    Eric
    Eric
    2005 Mustang 4.0
    1996 Camaro Conv
    2000 Ford Excursion
    "Darkness Falls"
    So i better not trade for this 93.. thanks i appreciate it.
    brink<br />1998 White Camaro 3.8L V6:<br />Flowmaster Exhaust<br />No cat (straight pipe)<br />Free Ram-Air<br /> <a href=\"http://www.cardomain.com/id/98camaro98\" target=\"_blank\">http://www.cardomain.com/id/98camaro98</a>
      wow moderators are spreading bad info and then locking threads with the bad info in them... thats no good...at least i'm man enough to admint when i'm wrong - navyblue
      the speed density thing is correct, i dont know about the transmissions
      also the gauges, and buttons on the 93 cars were grey with yellow lettering and the 94 + cars had black with white letters
      [ April 15, 2005, 11:03 AM: Message edited by: navyblue2000 ]
        trannys where
        93 4l60
        94+ 4l60-E
        and the 93 had diferent gearing in the t-56
        93 tb was diferent
        93 intake manifold and fuel rail where diferent
        93 also had smaller injectors
        [img]graemlins/popcorn.gif[/img]
        Wolf<br /><a href=\"http://www.cardomain.com/memberpage/249111/7\" target=\"_blank\">95 black t-top camaro</a>,3.4 5 speed,ud pullies,plugs/wires,de-shaft tb & gutted airbox, homemaid short throw shifter
          Originally posted by wolf:
          </font><blockquote>quote:</font><hr />Originally posted by StudlyCamaro:
          trannys where
          93 4l60
          94+ 4l60-E
          93 tb was diferent
          </font>[/QUOTE]That is also correct....I think the injectors for the 93 were 21#
          Eric
          2005 Mustang 4.0
          1996 Camaro Conv
          2000 Ford Excursion
          "Darkness Falls"
            wow...my bad guys :rolleyes:
            Thanks though for you all who thought I was perfect... I mean, one error (about a v8 on a v6 board to boot!) in 2.5 years of moderating...boy you guys sure know how to show appreciation!
            the 93's actually had the 700R4 transmission, not the 4L60.
            hmm, now some useless facts...
            you couldn't get a convertible in 93.
            the LT1's went for under 18k new with few options
            2011 Camaro LS 6M, in black.
              In 93 they transistioned from the 700r4 to the 4L60 so depending on what month your car was built you could get either one.....
              Eric
              2005 Mustang 4.0
              1996 Camaro Conv
              2000 Ford Excursion
              "Darkness Falls"
                The 4L60 and 700R4 are the same transmission (different name), the 4L60-E is where the difference comes in, since it is electronically controlled instead of hydraulically.
                --<b>David</b>--<br /><a href=\"http://bryant2.bryant.edu/~dsantore/index.htm\" target=\"_blank\">The <b>NEW</b> V6Bird Website!</a> <br /><a href=\"http://members.cardomain.com/thev6bird\" target=\"_blank\">Cardomain site</a><br />ΔX
                  Originally posted by TheV6Bird:
                  </font><blockquote>quote:</font><hr />Originally posted by merlinsrealm:
                  The 4L60 and 700R4 are the same transmission (different name), the 4L60-E is where the difference comes in, since it is electronically controlled instead of hydraulically. </font>[/QUOTE]Not true....If it was they would not have named it something different....The tail shaft is differnent, the valve body is different among so many other things the converter is differnent...Even the trans filter is different....
                  Eric
                  2005 Mustang 4.0
                  1996 Camaro Conv
                  2000 Ford Excursion
                  "Darkness Falls"
